BOL
My father in law is convinced that my amp is draining the battery even when truck is off. So today I installed a toggle switch between the amp and the fuse box. The power goes from the battery straight to the amp but since I installed the switch it doesn't work. I am trying to get it so I can turn the switch off so that even with the key off there is no drainage. Should I have a fuse on there too other than the one on the amp itself? Should I rewire it straight to the battery?
