- Oct 26, 2007
- Rapid City, SD
- Automatic
Tomorrow I am picking up a 97.5 explorer with the gtp 5.0. I have a 98 ranger supercab xlt with the 4.0. I have spent quite a few hours reading about this swap, and have a few questions remaining.
I plan to use the x engine and transmission, along with the current manual shift 1354 t-case and 99 explorer rear axle in the truck.
I have the 9" AA transmission to t-case adapter, is this the right one?
What is the easiest way to hook up the VSS?
Will the 97 x computer work with the 99+ fuel rails, or should I run the return line and replace the regulator?
If the rails will work, are the injectors the same?
Thanks,
Chris
Thanks,
Chris
