DanVB1
- Oct 24, 2007
- Age
- 66
- Automatic
I would like to offer some information I got from my brother who worked for AutoZone (and now O’Reilly’s) as a commercial parts driver.
He talked to a few professional mechanics that performed the Seafoam cleaning by adding it directly to the intake manifold via vacuum hose. A few said they hydro-locked the engine after the engine sucked up most of the can within seconds. A Cadillac mechanic actually destroyed a Northstar by doing this (broke a rod).
Coincidentally my brother had a similar mishap with his Camaro. Once the SF liquid got into his engine, it stopped (locked-up). After trying to restart, he broke the starter drive since the engine was locked! Luckily, only a starter replacement was necessary.
Bottom Line? If you attempt, Please do so slowly with caution. I did this to my Ranger by dripping the liquid into a vacuum fitting at the front of the engine using a large plastic lab pipette (“eyedropper”).
You can find the typical procedure on the net, but most sites do not warn of the potential disasters that await if done too quickly.
I hope this will prevent one of us from destroying our engine!
