No....not really.
Put some 4.10's behind that 2.9L....and you wont miss a 4.0L at all.
Some agree the 2.9L was very underrated from the factory.
later,
Dustin
Dustin, Only one word comes to mind....
I already HAD 4.10's behind my 2.9.
I'm comparing apples to apples, a 2.9 with 4.10's Vs a 4.0
with 4.10's and I don't care what you do to a 2.9, my
freshly swapped 4.0 utterly stock '93 engine (except
for borla headers) will stomp your 2.9's dick into the dirt.
It isn't about a puny 1/4sec 0-60 it's about cutting the time by a third.
It's about going up hills with the 4.0 part throttle in fourth where
with the 2.9 you had to be SCREAMING @ WOT in third.
there simply is NO comparison
Now yes, I'm the one who first pointed out that the power/CID of the 2.9 is similar to the 351Lightning, but that is an impediment to improving the 2.9, the 4.0 has much more potential, because if a 4.0 was producing the same power relative to displacement as the 2.9 it would make 193hp
I think actually getting 200hp form a 4.0 is easier than getting more from a 2.9 would be...
The same old problem applies the higher the performance is stock the harder it is to improve upon it.
Now as for mileage, I'm close to being a champion at squeeking mileage froma 2.9, my best of 26.2 over a full tank of gas (all highway miles) is fantastic
However running at the same speed towing my 2000lb trailer and my 2.9's would drop to the High-12's or low-13's.
That being said the 4.0 while returning from Wyoming managed high-16's
and low-17's over a 1900miles distance and six tanks of gas.
Honestly I don't expect the peak mileage with the 4.0 to
be as good, but EPA estimates for the 4.0 in the early 90's
were 20-21 highway. I can live with that is it is about the same as my average mileage with the 2.9.
I simply haven't had the chance to drive the 4.0 with the truck
unloaded on the highway to find out how it'll do, but a "tight"
4.0 has gotta be better than an aging 2.9.
where the 2.9 was always straining the 4.0 just seems to loaf along and do things effortlessly.
I would not only put my 4.0 up against ANY 2.9 in a 4x4 supercab, but I'd be fairly confidant going up against
MOST 5.0 installs in a 4x4 supercab.
AD
