jimmyfloyd
- Nov 7, 2017
1986 Ranger 2.9L 5spd 4x4
Trying to narrow down some issues. One of them seems to be this piece. i see it has a resistor label on it, but can't seem to find a replacement part. It has a Dark Green/Yellow wire on one side, and either a solid dark green, or Dark Green/Yellow out the other. Seems to go from the Ignition coil to the other side of the motor. Maybe to the TFI module?
Any help on where to get a replacement for this would be helpful. As shown in the pictures, the wire is in bad shape right at the edge of it, and I believe it is grounding out on bumps and causing the truck to stall.
