- Apr 13, 2009
- Reaction score
- 5,102
- Location
- Calgary, Canada
- '91, '80, '06
- Make / Model
- Ford, GMC,Dodge
- Engine Size
- 4.0,4.0,5.7
- 2WD / 4WD
- 4WD
I bought a 1988 RV 460ci EFI [for cheap], the PO figured the timing chain skipped a tooth. I tested for fuel and found the high pressure pump was fubar, so replaced it and it fired up. Idle was erratic and vacuum was low @ ~13-15 psi. OK, maybe the chain WAS gone....tore it down and NO, chain is fine. Crap. So now I need help in diagnostics. I pulled the distributor so I could get at the TFI and will test that tonight or tomorrow morning. While the front of the motor is off I plan on replacing the sparkplugs and doing a compression test. There is very little room to work on plugs/wires when the motor is together and the rad is in place.
Is there anything else I should look at?
PS; the unit is 40 miles from home and no parts places close by.
