Transfer case leak?
Ranger4x4.0
Poplar Bluff, Mo
God is great, beer is good, and rangers are awesome!
I can't really tell if it's leaking from a seal or somewhere else, but it's definitely leaking.
Also, while I am here, it also appears that oil is leaking from somewhere. There is a drop or two on the filter as you can see, but i think it's from when I changed my oil last night and didn't quite clean it up. I will make sure the filter is tightened later.
I've never seen a drop of anything under my truck except for a.c. condensation, so maybe these are nothing to worry about?
Sent from my SAMSUNG-SM-G890A using Tapatalk
Looks like a tiny amount of oil seepage from around the t-case fill plug.
A couple wraps of teflon pipe thread sealant tape around the plug should stop it.
Will do, while I'm at it, I'll change the oil, I'm sure it's way past due.
