2000 4x4 3.0 ATX.
I'm getting ideas about the 1.7 ratio roller rockers. anybody know how they affect the torque curve? since they basically emulate a bigger cam I would suspect they reduce the bottom end and move the peak torque to a higher RPM.
currently the gears are 3.73, its turning about 2500 RPM at 70 Mph. 4.10s are in the works, that would put the hi-way RPMs at about 2750.
torque improvement below 3000 is my goal, so do you think the 1.7s in combination with head porting would help or hurt?
also thinking of an intake spacer to make the runners longer.
