zaczany1
- Jan 1, 2017
so i have a 93 v6 3.0 ranger, i reciently swapped the motor and drove it for many miles. it broke down on me while driing home one day, after that i towed it home and started working the basics. i changed the distributor cap and rotor but no luck, i changed the fuel filter (it has a new fuel pump) and got it to start. but it was hard to start and ran poorly. it stalled in high rmp unless i slam the gas, it revs up fine, and drives, but stall like its flooded maybe.or almost like a clogged cat, so i took the cat off. no dice. changed the fuel regulator and spark pugs. still nothing. i also threw a second hand maf just to see but that didnt help. it seems once the motor is warmed up it runs good but if its cold it stalls and i cant even drive it. any advice helps, thank you
