the camshaft on the 4.0 has no provisions for a distributor drive, also on that note i have actually never seen a carburated 4.0, all the work would be 100% custom one off work. there is no real reason to convert a 4.0 to a carbed motor, the DIS system is very reliable, as is the FI system on the said motor.
you would need a 100% one off ignition system, a custom made distributor, a custom made cam shaft, a custom made intake. now worth it by any means
Do the 2.8's have the same distributors as the 2.9's???thats odd, but the again ive only worked on OBD 2 4.0's....so theres a possiblity its differentMhughes, you need to actually get your hands into a 4.0 and work on one .....
The 4.0 camshaft does indeed have a cam drive 'gear' on the back, just like the 2.9 and the 4.0 uses a blank oil pump drive, driven off the cam gear to rotate the oil pump. The 2.9 has this exact same setup to rotate the oil pump AND the distributor shaft. These setups are basically identical (see picture below - 2.9 distributor on the left, 4.0 oil pump drive on the right.) I have installed a 2.9 distributor on a 4.0 on an engine stand, rotated the engine and verified that everything works properly. All you would then have to do is get the ignition wiring harness / control box hooked up to work properly.
Now, are there any advantages ??? Nope - you would have to have a custom made intake to get the clearance for the distributor and mount a carb = $$$$. Then you would have an inefficient setup that wouldn't make as much power or have the driveablity of fuel injection.
Can it be done - definitely - I looked into it a long time ago - wasn't worth it.
Bird
Hmmmmm - the 96-00 4.0 OHV 4.0s (ODB2) were the exact same configuration as the 91-95 4.0 OHV 4.0's (ODB1).
Maybe you were talking about the SOHC 4.0 engines which are entirely different that what the OP was asking about????
Bird
The worst part would be the TFI distributor. (no advance).
Actually, the worst part would be not being able to use the distributor with the fatory lower intake as the intake overhangs where the distributor goes.
Bird
