Brownie Mobile
I'm back and with a new truck. Attaching pictures as well. Anyways its an 85 f 150 with 8 or so in of lift. 39.5 in tires all around a bad ass truck but I'm having issues. It has the engine from a 95 boss 302 ( it'll spin those 40s on dry pavement like its nothing). But the engine has beem converted to points for some reason and the intake is a 2bbl edelbrock I've definitely got carb issues and maybe you can help me out at idle it runs okayish prettt inconsistent misfire but not bad at idle. Once you start reving it gets a very steady misfire (sounds like the same cylinder everytime) . Once the secondaries open up runs like a top so I find my self luggint the engine so I can put more gas into it and run smoothly.also when I shift down its reallu rough almost exactly like bump starting. Other possible relevant info my tach goes down to 0 as soon as I let off the gas. Lemme known whatvyou think thank s.
