As the title said I'm after info. I'm interested in swapping out my Borg and Warner 4405 to a 1354E or maybe a manual version.
I've found 4405's in my area, but after finding the last two to be bad ( Major tail shaft play) I've given up on the junk.
What I do know:
-It will physically go in place of the 4405.
-My explorer has a regular double joint front driveshaft( so it will bolt up to a Rangers 1354).
What I'm not sure on and am hoping for some input from somebody who may have done this:
- Plug for T-Case shift motor. Mine is square and I'm remembering my Rangers being round. I could be wrong.
- Would I need a GEM module from the donor vehicle? So it knows how to operate the new t case?
- From a little google searching there might be interference with the gas tank
- What years of Rangers would be compatible with my 95' GEM module wise.
Now if I decided to go manual:
- Has anyone made a manual shifter work with the explorer center console?
- I'm sure my dash would light up like a Christmas tree without the GEM getting signals from the shift motor etc.
- Also another concern would be the axle disconnect getting the signal to connect when I shift.
Sent from my iPhone using Tapatalk - now Free
What I do know:
