- Feb 1, 2013
Hi, not really sure if this belongs in the V6 section or in an electrical section, so I appologize if the thread winds up needing to be moved.
So I was having some trouble getting my truck started a few weeks ago and I wound up getting stuck in a parking lot, unable to get the truck started. I wound up having a mechanic tow me in and take a look at the truck. They wound up replacing some components in the distributor and the wiring harness that plugs into the side of the distributor. It wound up costing me $300. Knowing that I got taken for a ride, I'd really rather not take my truck back there... for $300 I could have just bought an all new distributor and ignition coil... but that's the past now!
Anyway, the truck was starting well for a few days and now it's starting again. The truck tends not to start, and definitely won't start if I'm not holding down the clutch and the gas. I can get it to start just fine with a little starter fluid sprayed into the carb. It's really difficult to diagnose what's wrong because the symptoms are so inconsistent. Sometimes it will start, sometimes it won't. Sometimes if it starts and I turn it off it will start up no problem, sometimes it's impossible to get it to start again.
I've also got a fairly substantial oil leak. I'm not positive where it's from yet, but it's pretty bad. It only leaks while running. The only reason I mention it is maybe the two problems are related, but I'm not sure. I'm going to get some UV dye and see if I can't find the leak later today. I have a hunch that it's the valve cover or intake manifold since it seems to be coming from the top. Then again, it could be the distributor, but it was leaking before they dinked around with the distributor at the shop, so who knows.
