LBPete
- Mar 3, 2012
- Automatic
Hi all. I'm new to the forum so please be kind.
I have a 2000 Ranger 2wd coil spring flex fuel V6 that I bought recently. It's racked up 130k miles. I recently discovered it has the herniated oil pan gasket syndrome. I've done a lot of investigation on the web and see a classic tastes great/less filling argument regarding how to change out the pan gasket.
There are many posts about pulling the engine as a easier alternative to pulling the pan with the engine still in the truck. I see the logic in that but it's a lot of work too and has some risk on busting stuff in the process. Also, I don't see any easy way to unbolt and move the AC compressor out of the way without disturbing the lines. I don't have easy access to freon recovery and recharge equipment.
So before going nuclear and pulling the engine, I want to dig into the in car procedure.
In looking at it all the pan screws are accessible. Most of the pan sits behind the cross-member. There is certainly a clearance issue with the cross-member. I understand the need to jack up the engine to get clearance and there is a lot of on line discussion regarding unbolting the oil pump and dropping it into the pan.
The service manual starts with "remove flywheel or flex plate" but doesn't say anything about the oil pump. So the question is, is dropping the oil pump a work around for pulling the trans and flex plate or do I need to do both?
Next, choosing a replacement gasket. Any advantage to a particular brand? I see both Ford and some aftermarket brands have improved this gasket over time. I've read Ford TSB 03-5-3 and it recommends P/N 2U7Z-6710-AA. Is there a newer revision to the Ford part and procedure?
What about using just straight RTV? Has anyone tried that?
Sorry for the long post, any help is appreciated.
- Pete
- Pete
