Cut and Turned TTB
damn!!!:icon_surprised:
i would like to see those in person
i am thinking of buying them right now.....
thanks for sharing that:headbang:
All terrain vehicle. We have everything pretty much here: Rocks, Muds, Sand, and Pavement.
well they are a good way to go, i would consider running custom arms or 150/ttb arms at least to try to get the range they offer.
some skyjacker 4 in coils and maybe some 2wd ttb 150 springs out back
some rc jeep 6 in coils with e350 airbags would really let it shine for trail wheeling.
You NEED the extended axle shafts, don't you? Those are only $100? I'd find out more about that before I went too far.
They'd be great for the sand and mud, less so for rocks. Pavement it wouldn't really matter either way though.
Another active thread on this very topic right here:
http://www.therangerstation.com/forums/showthread.php?t=113066
I think the longer axles are needed if you go the +2, +4 etc wider route. The cost of these arms is pretty close to the SJ pivot brackets price here on TRS. I do really like the beefed up plating on these arms for sure. I gotta think on this. Most of my wheeling is sand, fire roads and rocks when we find them available. The description says up to 5" lift, I wonder if a 6" spring would mess up the geometry that much.
Ranger Ryan, post some pics of that tan BII in your avatar!
for 250.... that's about the price of good drop brackets. so why not??? lol
Seems to me that you are starting with the axle joints already angled some. That doesn't seem to be a good thing in my opinion. Starting with the axles shaft straight across, as when you use drop brackets, the joint has equal room either up or down. On that same subject, the reason I think you need longer shafts is not because of increased width, but because the shafts are angled. The reason there is a slip in there is because the axle needs to get longer as the knuckle drops. If you start out with the knuckle dropped, is there enough room in the slip?
Also, when you have lockers and are in bad country, you can find yourself with pretty much one single tire dilering all of the torque to the ground. Are those joints and the slip going to hold up with cut and turned beams?
I've nothing against exploring things and finding what works. Thing is, these axle pieces aren't being made anymore to my knowledge. You brake a shaft--it's gone. Most of the junkyard shafts are too whipped to trust. If you wheel a D35 TTB, you learn to take care of your stuff. I don't think you are going on Ebay and finding an axle shaft for a TTB D35.
he can run the 250 dollar reg beams with the combo suggested and stock shafts
Well I'm in for a set of the standard length C&T beams. We'll see what shows up. Going with SJ 4" springs and my full size lengthened arms.
I was thinking about buying those too! Except i'm not building a prerunner or anything! Good luck!
