Ctg1971
- Mar 28, 2018
So I've recently gotten a 91 ranger 2.3 5 speed and when I got it the fuel gauge didn't work or the temp gauge so a new sender fixed the temp gauge so I figured the same would go for the fuel gauge so I bought a new fuel pump sender and all installed it same issue dealt with it for about a month and today I pulled the bed and found the arm was stuck on the new pump so I warrantied the pump installed the new one and saw with the pump out it was full to the top of the tank on my way home the gauge would bounce between a half and quarter tank but when I shut the truck off I turned the key back on but didn't start the motor and the gauge reads right on full where should I start as far as checking for wiring or gauge problems? Thanks in advance and sorry for the long post just wanted to make sure that problem was as easy as possible for people to understand
