Tlee1214
- Feb 26, 2014
Ranger.. 1997 2.3 4x2 5 speed w/AC
Here's the story.. My truck runs lean. It throws the P171 code about every 500-800 after being cleared. The last two times I've looked at the freeze frame and it happens at low RPMs 1030-1070. When I run the truck plugged into the scan tool, my long term file trim is high (24) and the short term is more normal (4) but short term will increase slowly as well. Both O2 sensors are new and I cleaned the mass air sensor.
I'm thinking maybe an injector. I put some sea foam in and will continue to. Also am going to change gas to see if that makes a difference.
If anyone has any other thoughts that may be helpful it would be much appreciated.. this problems is getting annoying.
Thanks
Thanks
