Diesel_brad
Ok. I posted this same question on FTE with no luck. Hope you guys can help
04 , 4.0 5 speed
1. Now. when i first fire the truck it idles around 1500 then after about 2-3 min of running it drops to 1000. Is that normal?
2. While driving down the highway at 65 or so. If i let off the gas and push in the clutch the RPMs sit at 2000. I can coast like this for at least 10-15 sec with no change in the RPM.
Some times while driving thru town it will do the same thing while shifting
gears. Go to from from one gear no next highest and RPMs just sit at 2k or if i am below that RPM it will climb to 2k. When i get in to next gear it bogs the engine down as if i had my foot still on the gas.
Any suggestions? I changed the TPS, IAC, and have checked for Vaccum leaks carb cleaner. I bought what i thought was PCV and tried to change it(passenger valve cover) but it does not hook to the tube leading to the air intake hose. Some one on FTE said my PVC is under the intake?
Please help. This truck is driving me nuts since i bought it. No i dont have a scanner to run codes or check parameters
04 , 4.0 5 speed
