- Nov 16, 2017
Hey guys ive got a 1993 ford ranger 2.3l 8 plug, 5 speed, xlt model.
my ranger is currently not starting for me just cranking? need help!
it all started with my harmonic balancer and timing veins separating, beliven it had takin my crankshaft sensor with it as well i replaced the sensor and i fixed the hub and veins myself to ford spec's, trust me i made sure 100x's. still wouldn't start replaced the DIS system, plugs, wires, coil packs, and ECM!!
i've found that when i pull the spout (spark out test plug) is unplugged the truck runs fine and defualted timing of 10 degrees BTC, and when i plug it back in while it has started and running while it was unplugged at first the timming jumps to 10-12 degrees BTC?? i put a timing light on the darn thing while spout plugged in and was getting 10 ATC?? my fuel pressure at rail is 40psi and while it ran it was 32ish psi, and the engine has compression too, if i remember it was about 145, 155 in the ranger? good or Bad??
need some help badly ive put to much into this thing between money and time away from family.
