Introduction
Some 4×4 enthusiasts modify their suspensions and use coil springs from a 1966–1977 Ford Bronco. One of the challenges is mounting the coil to the Dana 35 TTB axle beam. In this guide, we’ll show you step-by-step how to make it work safely while using heavy-duty cups.
Step 1: Understanding Coil Mount Differences
The Ranger coil is sandwiched between a coil seat and a dish-shaped washer held in place by a nut on the center mounting stud. The Ford Bronco coil sits inside a cup and slides into the square hoop, as seen in the photo below. To mount it on the Dana 35, the original coil spring mounting stud is removed and the Bronco lower mounting cup is secured. A hole must be drilled in the center of the cup for the stud to fit through.
Mounting Early Bronco Coil Springs on Dana 35 TTB Axle for Ford Ranger
Step 2: Using Heavy-Duty Lower Coil Cups
Heavy-duty lower spring cups are available for extreme-duty setups. The photo below shows one of these cups. A hole is drilled into the center to mount it on the Dana 35 axle, and the cup is cut to fit around the steering knuckle where it mounts.
Extreme Duty Lower Coil Spring Cups for 1966-1977 Ford Bronco
(Extreme Duty Lower Coil Spring Cups, 66-77 Ford Bronco)
Lower coil spring cup drilled for Dana 35 TTB axle
Ford Bronco lower coil spring mount installation
Step 3: Custom Mounting Options
Some users fabricate their own mounting cups. In this setup, the coil sits around the mount, and the Ranger’s original dished cup can be reused to tighten against the ring on the cup.
Custom Ford Bronco coil spring mounting cup on a Ford Ranger Dana 35 TTB
Ford Bronco coil spring mounting cup on a Dana 35 TTB
Step 4: Comparison With Dana 44
This is what the Bronco mounting cups look like when installed on a Dana 44 axle.
Ford Bronco coil spring mounting cup on a Dana 44 axle
Tips and Notes
  • Ensure all holes are properly aligned before tightening the coil cups.
  • Check coil alignment with steering knuckle clearance.
  • Use heavy-duty lower cups for extreme-duty setups.
  • Double-check all bolts and torque specs before driving.
Related Articles
Frequently Asked Questions
Can I use early Bronco coils on a stock Dana 35 TTB?
Yes, but you need to drill and modify the lower coil cups to fit the Dana 35 mounting studs safely.
Do I need special tools for the installation?
A drill, wrenches, and heavy-duty lower cups are recommended for proper mounting.
Will this fit on a Dana 44 axle?
Yes, the early Bronco cups can also be mounted on a Dana 44, but the installation may differ slightly.
About The Author
