your thoughts
sparkey
nc
Hello? I have a project that I am working on I have two frames that I need parts off of a long bed and b2 frame. The question is which one would you use I can sell the one I don’t use and, I cant figure out the one that some one would need more of the two, The ranger body that came of the long bed was rusted kind of good and I took the inner fenders an core off the b2 to fix the excab where it had been wrecked if it was some on here what would you use
are you trying to make 2 frames into one useing good parts or useing them to fix another truck?
Yes the extended cab truck is tow wheel drive going 4x4 the frame I use will be toast when Iam done with it
pretty much its more work than its worth to swap parts from a 4wd frame to a 2wd frame.. would be better either selling both frames and buying straight axles or put the body on the 4x4 frame ..
Ill be doing all the work don't mind it enjoy it realy just trying to figure out which frame is in more of a demand. so I sell it
