Wtb 4x4 m5rod adapter
Foamyz763
Forum Member
Ford Technician
Dolan Springs
AZ - USA
Other
Neon
Vehicle
2.5 (4 Cylinder)
Total Drop
31 inch
Wtb,the adapter section to mount the transfer case on an m5rod,there are only 2wd and automatics at every junkyard around here.
Thanks
I just moved you to the parts wanted forum.
I think there is a couple different versions on those too.
With or without manual transfer case.
I might be wrong though...
Electric t-case won't care either way.
You need at least the output shaft from the trans to adapt it. Not a simple swap, it is one of the first parts to go into an empty transmission case and the last to come out.
That too.
I guess I thought he had a broken tailshaft housing.
I rebuild these transmissions,I just need this section.
  • Wtb 4x4 m5rod adapter
Good luck. Maybe some weekend posters will see this.
I hope so. Have a safe memorial day.
So you have a 4x4 shaft already installed, just need the adapter?
That baby there
One or two,if you have them.
I have one for applications that do not require provisions for an OSS.
$260 shipped anywhere in the contiguous United States.
Well that's definitely us,Mama told me I have to save up the other 60,I have the 200,parts budget wise.
