won't start
What tool do you use to get to that hard to reach bolt on the starter? We are going to harbor freight to try to buy an extra long ratchet. With maybe an adjustable head for tight spaces. Have to break that nut free with two or three inches to move
We don't have Jack stands right now. All that is 2.5 hours away
Paid a local mechanic 60 to help us get the starter replaced. He had a jack and Jack stands. We are broke down by mechanics by the grace of God. Now it is acting flooded. We are going to pick up Tommorow. It almost starts? Mass air flow sensor. Going to put starter fluid on it and see if the new fuel pump is working Tommorow
Obd scanner won't work. Fixd obd scanner won't read or it says no codes. Before it was giving codes like maybe fuel filter. Vacuum leak or oxygen sensor.
There are no codes that say fuel filter, vacuum leak, or oxygen sensor. It sounds like the tester is set to display a guess instead of the actual DTC's. Autozone uses one like that to sell unneeded parts to people who don't know better. A code that indicates an O2 sensor out of range is a symptom, not a diagnosis, and almost always indicates an engine running rich or lean.
Please get some diag done, it'll be cheaper than buying a load of parts you don't need.
