- Sep 29, 2021
- Manitoba, Canada
There is a wire that's been disconnectedYeah the pump running will not hurt anything, the fuel pressure regulator will allow excess fuel to return to the tank.
Check the smaller ground wire that is supposed to be connected to your negative battery terminal. It should have a round connector about 6-8" down the wire and then split off into two wires... that's the ground for the ECM and fuel pump, if it's not connected or has corroded off, you will have this exact issue...seen it happen a lot.
