Won't Start - 1998 Mazda B4000
futon
10+ Year Member
💻 TRS Socials
London
ON - CAN
Other
2014 Mazda3
Vehicle
Drive
2WD
P265/75/R15
What happened:
* Oil changed at a "quick" lube I've never been to before (I know)
* Next day it drove fine, I stopped for 10 minutes to grab some stuff, and now won't start.
* Single, strong click from the solenoid.
* No grinding, doesn't seem like motor spinning.
Observations:
* Engine is over-filled with oil, and there is a small leak from the filter. My first thought was oil dripping onto starter and fouling it up.
* Battery tested fine during the oil change (12.6v)
* Push start works, and truck runs fine once it's going.
What I've tried so far:
* Boosting with a battery pack.
* Boosting with another car.
* Brand new battery.
* Brand new starter motor.
* Cleaned starter wires.
* Cleaned battery terminals (on old battery) and cleaned the frame ground connection.
* Swapped two of the relays.
Seems similar to this one, but resolution there was just cleaning the battery connections?
I'm too chicken to try jumping the starter with a screwdriver.
I'm assuming there's an issue with the power cable running to the starter. Signal wire works so solenoid engages (strongly), but motor doesn't engage.
I'm not familiar with electronics, but I suspect my next step is to try testing the wires?
Theories on why this happened the day after an oil change?
The battery cables/starter wires can rot inside and show very little noticeable effect from the outside. Take one loose and wiggle it. Does it feel "crunchy"? If so you need new cables.
You might be able to test the starter with a pair of jumper cables if you have a good (large gauge) long set.
Yeah, turned out to be gunk/corrosion at the positive terminal. I was about to do a voltage drop test to the starter to figure out which wire was bad, and decided I'd try cleaning up the terminals (again). This time it started, but a bit rough. Cleaned up the positive terminal even better w/sand paper, et voila. Starts up strong and smooth now. Sigh. Well, at least I learned how to change the starter.
