Windows 11 requirements
Gotta say off-lease Lenovo is a great way to go IMO. I'm on my 3rd. The first 2 are still working. One is a Pentium D system with extensive mouse damage and just keeps going.
Lenovo is the (admittedly sold off to Chinese investors) former IBM PC division. They do often have proprietary power supplies and motherboards to match. There are often adapters available to use standard ATX power supplies in place of the stock ones. I have to research each model before I buy it. AFAIK the current machine (P520) doesn't have any adapter options but it came stock with an 80+ bronze 900w and dual 8 pins for GPU.
Yep. My P300 workstation now has a standarrd 80+ Gold ATX 750-watt power supply with an adapter harness to interface with the Lenovo motherboard. I did that after the OEM proprietary PSU took a dump.
The enterprise level Lenovo Thinkpads that I worked with at my job several years ago (2016-1017) were built like a brick sh!thouse. slower than crap, but that was likely due to the fact that they were close to 5 or 6 years old at the time. installing ODBC drivers for Oracle 11 took forever. the new Dells that the company bought to replace them were way nicer, way faster. the second round of Dells that replaced the first round were complete junk out of the box. most had hardware issues and design was poor compared to the first round. I thought i was getting an upgrade when they told me in 2021 that my 4 year old Dell needed replacing due to complaints of batteries swelling up. (mine did not have the issue and worked perfectly) the new ones... man I hate that pos.. been dealing with it for over 4 years now.
The consumer level Lenovo Thinkpads are also junk. got one of those in 2021, and something in it does not play nice with Office 365 which my wife needed on it. it would slow down and basically take 4 to 5 minutes to type in a web address because of maxing out cpu and ram. get rid of Orifice 365, it was ok. replaced that with a similarly spec'd ASUS laptop less than a year later which I found out had the same motherboard as the Lenovo, the only major differences were the ASUS had a back lit keyboard and the Lenovo had a touchscreen. ASUS has been rock solid, Orifice 365 works fine on it, and it has been handed down to my 14 year old son who uses it to play minecraft and school work/ papers.
For my Win 11 laptop, I got an MSI "gaming" laptop from Costco back in January. pretty decent laptop, although i use finger quotes on gaming as the GPU falls a bit short in that category. but it has a 1tb ssd drive, 32GB of RAM and works great. got it on sale for 700, normal price of 1000.
AJ
I've still yet to set up the new computer... this whole time thing, I'll get to it once it actually gets cold or rainy, whenever that might be...
you are probably the victim of a browser hijack. start looking at all of your extensions, look at dns settings and make sure that they are what your ISP provided and something weird. also would not hurt to do a complete virus/ malware scan.
As mentioned by John 97, Microsoft is extending Win 10 to October 2026 for critical updates which should keep you afloat for another year. my main computer is over 9 years old and I went that route as there is nothing wrong with the computer and it still performs well.
but it is an HP... so there is that :D
AJ
I managed to reset browser settings. seems to have improved.
are Apple computers a good way around the debacle of windows 10 support ending?
or are they even worse at forcing upgrades?
UGH. No. They don't force upgrades. Just one day your shit don't work.
I'm getting ready to try Linux. Bazzite in particular as it is focused on gaming and is a stable release. I bought a new hard drive and will swap that for the one with windows on it.
For others willing to try Linux, you also have the option to boot from a USB with the Linux ISO of your choice. Lots of videos online, going over the process to create a bootable USB.
distrowatch.com maintains a list of the top 100 Linux distributions. The site is a great way to familiarize yourself w/distros, download links...as well as youtube.
A neighbour asked to borrow a scanner. I loaned her an old canon usb scanner I had collecting dust. She called later, because her windows computer wouldn't recognize it. I mentioned she probabily needed to download a driver.
I ended up loaning her my linux laptop, so she could scan her documents.
I sometimes forget how fortunate I am, for not having to deal with windows :P
I have Bazzite downloaded to a USB. I'm going to try it running off that first as you suggest. Apparently the same USB ISO is used to download onto disc as well once I decide its for me.
Correct.
Once you've tried the distro, you have the option to install it onto your internal hard drive. This is a great way to try/test various distros before actually installing it.
For example, you may find that wifi doesn't work when you boot off the USB. You can try a different distro, or research what's involved in getting wifi to work on your hardware.
HTH
If you are new to the Linux world, Ubuntu or LinuxMint are probably your best options for ease of use and configuring. it is move involved than windows, but not too bad, and it is getting easier and easier with each release. as said above, install to a USB (you might need a third party app like Rufus to format the USB to set it up, but there are some good how to's out there that make it pretty easy. boot it up and play with it, if you like it, use the option to install.
Also, harddrives are pretty cheap, for well under a hundred dollars you can buy a new 1tb ssd and swap out your windows harddrive for the fresh one. this way you can keep windows if you need to go back to it, all you have to do is swap the drive and you are good. (assuming you have a tower case or a laptop that has actual access panels to the harddrive... most of the laptops in the last 5 years you have tocompletely dissassemble to get to the harddrive...)
Have fun!
AJ
The last distro I used was Manjaro. It was fairly easy to set up. It is based on Arch.
Getting a Samsung laser printer to work on it was a headache.
