drive your truck over to where it is and measure it up to your frame. also look closely at the frame of the ranger it came off of if possible. it's not uncommon for the hitch to have an extra bolt hole on each side that your frame may not have. most just drill those holes into the truck frame and bolt it right up. good luck.
Ok, hopefully I can get around to it before it gets sold. My feeling is that it will fit, because of the huge similarities between different generations of rangers.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
