Will a 92 92 4.0 swap to a 94 4.0 w/california emissions ?
Old94
bettendorf ia
if You Don't Like My Smoke Don't Sit By My Fire
My 94 4.0 ranger is a California truck... I have spun a bearing.. I have a donor truck which is a 92 with a 4.0 I live in Iowa so finding a California emissions donor will not be easy...lol so what will need to be done in order to make this 92 work in my 94 ? I'm pretty sure I will need to use my 94 intake and injectors but what else ?
You will use the camshaft synchronizer and egr and the engine harness from your 94 4.0 that is bad and put it on the 92 engine. Because of this you may also need to use the driver side exhaust manifold from the 94 and put it on the 92 because the egr connects too it.
You may have to just put the entire intake manifold from the 94 onto the 92 block and replace the gaskets while doing it. And ya switch the injectors
Hope this helps
Of course you could always just take the 92 comp and put it in your 94 so you don't have to worry about changing all that crap.
So ya you got some options
