Whobbly rotor
Ranger_Dan
Schenectady, NY
My right front rotor keeps coming loose, I know this because it starts to make a thumping noise at higher speeds, the other reason i know this is because every time I tighten the nuts or whatever they are, they always seem to come loose, I wish it was a crown nut that way I could use a pin to keep it there.
Maybe I'm missing something?
Whobbly rotor
Whobbly rotor
Thanks
Dan B.
I'm sloppy with grease, haha, don't worry, after this photo I cleaned it up.
I'm assuming you know how to set up wheel bearings here...
The outer lock needs to be torqued to 200-250 ft lbs.
Hard to tell with the grease on it, but am I not seeing the locking washer in between the two nuts?
(washer shown in this pic clicky)
