2.5L ('98-'01) whirring noise
california
2.5 (4 Cylinder)
stock
yr2000 4cyl mt 340kmi ranger recently started making a "whurrrrrrrrr" whining noise when driving 1st and 2nd gear and also while in third gear when loaded with 500lb in the bed.
noise stops and then starts again between shifts.
"WHRRRrrr *shift* WHRRRrrrrrrrr *shift* WHRRRrrrrrrrrrrrrrrrrrrrrrrrrr...."
the noise started about a week ago. perhaps higher speeds drown out the noise. any idea whats going on?
additional notes:
-iirc the noise also came for about 2weeks and then stopped a few months back.
-i do a lot of irregular driving, some
weeks ill drive maybe one short 5-30mile
trip, other weeks i may lay down 1000miles.
-also i have p0442 fuel evaporate "gas cap" code, could it be related?
-my belt started squealing in the past 6weeks or so. i changed serpentine belt in 2018. the belt was barely squeaking during todays 200mi drive.
-also for past 2years ive been taking a few 500mile trips with a 1500lb trailer. and recently i did the drive with a 200lb buddy with about 800lb in the bed (no trailer). we had to take turns driving through hilly highways and whenever i would wake up, i would look at the computer and he would be at like 90-100% load. fkkkk i hate when other people drive my truck
....iirc ive heard a transmission with no oil before and its a similar noise. when my truck was last making noise, i checked trans fluid and it look clean and purple... i think.
iirc i changed trans fluid about 2-3years ago.
google search query for "whurrring noise" didnt bring up much.
does it sound like it's coming from the transmission area? If so either the throwout bearing is going out (loading them like having the clutch disengaged sometimes quiets them down) or the pocket bearing bearing between the input and output shaft in the transmission or maybe the front bearing on the counter shaft... unless you got a mouse nest in the bellhousing or something dumb...
i cant really tell where the vehicle noises are coming from inside the single cab, how do i differentiate between engine noise and transmission noise?
*edit*
i popped the hook and pulled on throttle cable and it really sounds like its coming from engine bay. cant differentiate if it is coming from engine or PSpump. any ideas how to differentiate?
*edit*
i think it is power steering pump becuase the noise happens when press on gas pedal in neutral. It does sound different from the typical PSpump whine.
could it possibly be due to engine? dipstick oil level looks fine, but i do have to p0445 evaporative leak "gas cap" code.
any ideas how to differentiate engine whine from PSpump whine?
cuase it reeeeaaaaallllly sounds like its coming from the engine. sounds like a bunch of air being sucked into something, like a vacuum noise.
*edit*
any chance this could be power steering pump whining? mine has always leaked a little bit out of a boot but has recently started leaking a lot all around the rack and pinion and high pressure hose ends which i am looking into replacing right now. any way to test this out? also could excessive power steering leak and loose fluid be cuasing my belt to squeal? /
ive been losing about 1/2oz of PS fluid every 6 months for a few years now.
its recently ramped up to like 1/2oz every 6 weeks
and i think as of lately it has ramped up to like 1/2oz every six days....
im trying to think of ways to test if whining is coming from the PS pump. my gf drives stick but refuses to drive my clutch cuase she doesnt like that she has to press the clutch pedal all the way down to shift *rolls eyes*
man, im always reading threads/posts/coments about "my ranger made is at 350kmi and ive only ever replaced a clutch plate and a control arm" uggghhh, lol
