where to mount hi-lift on B2
awesome, like how you mounted it. may just borrow the idea if you dont mind!
its worked good for me go for it
you said you had a 37" mounted to the stock rack, looks like you beefed it up a little what speacial did you do for it just curious
ah, ya'll arent but a state away. Ya'll making any plans to hit uwharrie?
my spare is a 35x12.50 i had cut the body off above the bottom mounting bracket so i had to make a mount
i only have 1 thing bad 2 say about this if i see it correctly (its bolted on ) that could present a problem i would weld the bolts to the angle iron and find a wing nut that fits on the other side and us that to ease removal
my idea won't be ideal for alot of ppl. but i'm going to remove the stock rear bumper, buy two wheel studs, and matching locking lug nuts. then press the stud into the two holes on the black brackets off the frame then mount the high lift jack AS my rear bumper. it will be high and tight to the body. just the right length, easy to get to, and with locking lug nuts it will at least deter ppl from stealing it, tho im moving to a small town!
the bolts were tack welded the tack broke on that one bolt it will be welded back before it hits the trail again
yeah i would def retack weld that but good to see you were ahead of me lol.
how do you have it attatched on the jack side?
just nuts on the jack side i need find some wing nuts for it
