post of pics of where you have your amp mounted. i need inspiration. im thinking under a seat or on the back wall part, but im not sure. thanks
Mine are just mounted to the box but since this is a transmission line enclosure there are port walls everywhere which gives it internal bracing and its built very well so the box doesnt flex at all.
i still like your setup mang...looks clean...i wish i woulda went with AQ amps...but i didnt...went with a sundown SAZ 1000d and a Hifonics 4 channel...im overall happy.
. I should have did this before i put it in but i wasnt sure how it would sound in my truck.and to the guy that glued the piece of wood to the back wall.....you were worried about holes in the metal but did you think about how in gods name you were going to ge that glued piece of wood off the back wall?
I just wanted to spring for matching amps this time and a sundown 1000 or 1500 and a 50.4 or 100.4 was just more than i wanted to spend. I still need to bedline this box but its just a pain unhooking everything and taking out a seat to get the box out so i havent yet. I should have did this before i put it in but i wasnt sure how it would sound in my truck.
here is what i did with my set up.... http://www.therangerstation.com/forums/showthread.php?t=53862
no offense but you shoulda NEVER used housing carpet on those....if you get some regular speaker box carpet and cover them theyll look 100x better...if you wanted to go all out take the carpet off bondo em up and then paint em. and if theres only one layer of the fiberglass mat on there good luck.
