I ran 12.5's on an 8" wheel with 0 (4") offset on a BII. Avoid anything less as it will surely rub inside. On full articulation, my rears rubbed against the plate....
12.50s on 8" with 3 5/8" backspace on a BII. 3 1/2" lift minimum required. They will hit the radius arms at full turn in front and the rears will hit the fender lips and inner fender on full articulation. 10" rims are real hard on the front wheel bearings and the rubber will hit the fenders everywhere without more lift and/or cutting. 32X11.50s on 7" rims clear well with very little modification. Gen 1 BIIs have even less front fender clearance than my 89. I pulled my 3 1/2" lift and put roughly 5" kit on to minimize interference.
i have an 87 b2 with 305/70/16 on 16x8 wheels, not sure what the back space is on the wheels i have, but the tires are real close to the inner fender well on the rear
Most 16x8's have a GM-type offset regardless of the bolt pattern, meaning that there is more backspace (around 4.5" or more) than Fords need and the tire will be closer to the body.
The 16x8 with the least backspace I've found are the Pro Comp 1069 and 1089 with 4.0".
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
