I started with Fox Vert mounts, ended up with a contraption that moved the engine 1.5" forward and 1" up, along with redrilling the crossmember because the Vert mounts didn't line up with anything whatsoever.
I am using a stock 5.0 F150 oil pan. I've also slid the engine forward enough that my valve covers will come off and clear the brake booster and the heater box. I reworked my core support so that my radiator is mid mounted to buy extra room, but that also means that my engine, transmission, and transfer will all come out the front in one piece.
There's a dozen ways to go about this, and none are going to be all direct bolt in.
