What makes a good extended Vent Tube?
dhinch279
DeSoto, MO
I have a 6 inch lift, 33's, a manual t-case and a few other parts ready for my 94 ranger,
but before I put that on I need to put extended vent tubes on the T-case and Diff.
What kind of tube do you use and where do you run it to? I am just trying to get ideas, so feel free to add pics or anything that might help.
Also should I (or can I) put vent tubes on anything else(transmission, etc)
I just used 3/8" rubber fuel line.
On my diff, I basically ran a longer tube up behind the taillamp and then pointed it down.
I got alot of backwater and it gets about a foot to two feet deep, I've learned my lessons about water in the axle!:annoyed:
Thanks, thats what I had in mind for the rear diff. What about the t-case and front diff?
Seen alot of people use the curly air hose.
I ran the front diff breather up under the hood into the clean side of the air box, the rear goes into the tail light.
wouldn't the vent tube to the airbox possible suck some oil into the intake? I guess not enough to really do harm, but I definately like that idea especially if you have a snorkel, cuz then your whole truck is sunk before you get any water in the diff
Mine is snorkle'd. Its pretty hard to have any oil to go up the vent tube, the vent isn't submersed in oil and also the vent tube is about 5 feet long...thats along way for 90wt oil to travel.
while on subject, since the tranny and t-case use seperate vents(and ATF), could you run a T for both of them that way you only have to run one hose? that way there 2 hoses going to the engine compartment instead of 3
One thing I haven't seen mentioned yet is the need to water-proof your electrical connections, distributor (if equipped), and ECM. They don't have to be water-proof, but at least packed with dielectric grease and packed in some type of water-resistant enclosure like a Tupperware or plastic bag...
I run 3/8" steel line up the frame, Both axles, trans, and transfer end up all connected then connect them to the air cleaner. I've done this on a dozen trucks with no bad effects.
Last year I swamped the 'frog so deep that I could see the water lever through the drivers window. I didn't get any water in any of the axles, trans or transfer. The ECA (computer) was in the stock location, uncovered, and didn't have a problem. I did get a little water in the air cleaner and the dizzy though.
