what is the gear ratio?
remington115
What is the gear ratio in the diff on a stock 1996 ford ranger xlt 2.3l
whats the axle code on the door tag? its either going to be 3.73s or 3.55s more or less 3.73s
some 4 bangers got 4.10's...
the answer is "it varies". the only way to know is to check the axle code on the drivers door sticker and look up the code in the tech library.
You can also check the tag on the diff housing, it will be attached to a bolt holding the diff cover on, write the numbers down and ill let you know what you got
