- Aug 14, 2007
- Age
- 40
- Manual
Are the axle beam brakets the same and just longer coils, and you use the factory block under the rear leafs. Or are the axle beam brakets longer?
Welcome Visitor! Please take a few seconds and Register
for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
The 8" kit comes with longer brackets, yes. It's also not available as a Class II kit.
I don't recommend the 8" kits at all, the steering is basically impossible to correct properly without building some type of centerlink linkage for it entirely from scratch (it's beyond where you can modify the Superlift Superrunner kits).
If you want more lift than 6", I would use a bodylift. Another option might be SAS, the steering is easier to deal with on a SAS at those heights.
Being that high up is going to also raise your CoG to a point of being impractical for some types of wheeling (unless you swap full-width axles under it).
the 8" comes with rear 6" springs and 2" blocks, also the radius arm drop brackets are 6" brackets. every thing else is 8" stuff. i think the biggest problem with the 8" skyjacker not steering very good is the radius arm brackets, they throw your caster way out of wack
