What do you do with an overturned semi?
Looks like someone forgot to engage the parking brake.
..... they had to leave the engine running. there is no way that would have went with out the engine being on ........ unless by some freak the driver put the truck in neutral before he climbed out............
it only takes an hour for the air to bleed completely out of the tanks, if you drop below 25 psi the parking brake automatically sets.
I guess that truck was determined to cause a traffic jam.
If you listen close you can hear the engine rev as it starts forward.
Sure it wasn't one of the other trucks there?
I am amazed it took off like that... I mena unless it was a super steep hill... which it didn't look too steep that thing got going FAST! even for a semi.:shok:
Maximum Overdrive
You mean the engine was still running the whole time the rig was on its side?
I'm thinking it was left in neutral.
Listen closer..
Indeed. The engine was NOT running. Listen at the very end, after it slides down the hill and hits the other truck. You can hear the air escaping from the truck's system through a broken line. It was left in neutral, with the parking brake off. Once uprighted, any grade will start it rolling again until something stops it.
Our Mack's sit all night and don't bleed off low enough to pop the tpv.
I wouldn't expect it to be running at the end anyway, most accidents trigger fuel shutoff switches.
beer is good god is great PEOPLE ARE CRAZY:icon_surprised:
