What do I need to grab...
86MUDRCJ
Sheridan, CA
I might be getting a 3/4 ton Dana44 but the kicker is I ha ave to pull the axle itself. Anything besides everything that's on the axle I should grab?
Front axle or rear? what year truck is it coming out of and how do you plan to put it in? leafs or coils?
It's a rear axle out of a 74 f150 and I'm just gonna use leafs.
A F150 shouldn't have a Dana 60 axle. A F150 should have a 9". Does it have 8 bolt wheels? Either way grab the u bolt top plates because they will have the correct spacing for the diameter axle tube you are using. It might not hurt to grab the driveshaft so you have the end you can adapt to yours if you have to.
