What diffs are bolt in and go for 91 ranger?
chris015
10+ Year Member
Friend has a 91 ranger,manual,2wd that has a blown diff. The local pull it yard doesnt have any rangers right now,he needs his truck fixed before monday. We arent too concerned about gear ratios etc. he just needs it to run.
Whats bolt in and go interchangeable for these trucks? HELP is appreciated!!! thank you!!!!!!!!
1990-2009 axles will bolt in, however the width changed for '93, so if you don't want it a little wider, stick with '90-'92 axles.
'83-'89 axles will also bolt in, however the pinion flange is a different size (smaller).
