- May 15, 2020
- Age
- 71
- Atlanta
- State - Country
- GA - USA
- Other
- Manufacturers factory tour, maybe big dealership tour
- Vehicle
- Ford Ranger
- 4.0 V6
- Total Lift
- 97 stock, 3” on 87
- Total Drop
- N/A
- Tire Size
- 235/75-15
- My credo
- Never put off ‘til tomorrow what you can put off indefinitely
I don’t take my cap off as often as I used to. Back when I had my first Ranger I took the cap off frequently when I’d need an open bed. I used to wax the heck out of the bed rails to try and keep the foam tape from sticking so bad. Now when I need an open bed I just take the F-150.
I did find that the bulb style seal almost requires extra clamps. Or to bolt it down.
Setting a cap on a plastic bed liner is a recipe for problems, you will never get a good seal for one reason or another. I’ve always either used no bed liner or one that fits inside the bed and not over the rails.
I have found that older caps have a tendency to leak around the windows and stuff, especially fiberglass caps. It’s sometimes really hard to notice. I haven’t done it yet, but I’ve heard you can pull the trim, pull the screws and replace the seal there with butyl rope.
I would try a local cap/camper store for the seals. A good shop will sell you the stuff without a hassle.
You’ll never guess, but I got a deal on the fiberglass cap, and I got a deal on the bed liner when I got the truck. It’s a little weird to put the cap on top of the bed liner that goes over the bed side, but the only times I take the cap off is when I’m going to put gravel or something nasty in the bed, and I’d rather protect the truck. I’ve had it since 96, and I’m hoping I can make it last…
I do hate to do things that affect the overall look of the truck…
Oh, and I did take the side windows out and reseal them about five years after I got the thing. The biggest problem I’ve had over the years, is that I put on one of those rail system roof rack things, where the brackets can slide forward and backward in rails mounted directly to the cap. I had to take them on and off a couple times to finally get all the screw holes to seal, and now after 25 years of having the rails, the top of the truck is all warped since it doesn’t drain water around the rails, it’s like a little swimming pool. The only reason I never addressed that, is you have to be about 6’ four to be able to see up there at all.
