What did you do to your 2019 and up Ranger today?
Probably the last show of the year. Luckily the Steelers were playing in Ireland so the game was on at 9:30 AM. JROTC sponsored show at the Beaver, PA high school. Just clay bar'd and waxed it last week so a quick wash and spray of tire shine and all was good. 101,000 miles on it.
Just got back from a week-long trip to Taylor Park Reservoir in Colorado. A 2500 mile trip altogether.
The truck was a beast. Great handling in those mountains.
CMOS
Post-trip cleaning and check-up revealed that the hose supporting the fan motor wires finally crapped out so I did the old @sgtsandman zip tie fix.
Wait, - "fan motor wires"?
My 2023 has a mechanical fan with a thermal clutch, like in the old days.
Is this an upgrade?
CMOS
They might have changed it back. Mine and John's truck has a wire harness going to some kind of coupler on what looks like a clutch fan. There is a janky hose mounting contraption that holds the electric component in place as well as the wire harness that goes to it.
That hose is known to break, allowing the harness to drop down and rub on the fan mounting nut. If let go, it will eventually wear through and short, blowing the fuse and taking out a 5 or 6 other things on the same circuit. As a result, an oil pressure code and warning message pops up and puts the truck in limp mode.
The fix is to replace the cheap hose with a piece of fuel hose and either secure the wire to that or to the lines that run across the front of the engine.
This is happening today.
It’s hard to tell, but the bumper is on. It was more difficult than anticipated. But manageable.
Just a FYI...
I edited your last couple posts...
If you click the word insert on your thumbnails after you attach the file.then click full image... the actual image will appear in the post and not just the thumbnail.
Bumper looks good!
Thank you. I will that from now on.👍
I did it. Whhooo Raaay.
