what might be usual suspects as to why a 4.0 EFI engine is going to run rich?
im referring to a rebuilt motor, so even improper engine setup could be involved (say for instance the machine shop putting the wrong heads on changing cylinder volumes enough for detonation).
i am going to verify ECT, MAF, and O2 sensors as they are the ones i know would affect the fuel tables. is there anything else i should look into?
after a week of driving this thing (its not a DD) i noticed black deposits creeping up the tail pipe, and a nice pungent smell from the exhaust. i am not loosing coolant, so i assume there isn't a coolant leak causing smelly exhaust.
the only thing different from stock is an acell coil pack and headers. Also no CEL's so if a sensor is out, its only out enough to throw off the fuel tables, not throw a code.
