- Sep 22, 2007
- Michigan
- 2.9 V6
- My credo
- A legend to the old man, a hero to the child...
T stat i just replaced a couple months ago.Maybe a stuck thermostat or faulty water pump?
I buy the “lifetime” warranty water pumps at Autozone since it means as long as you own the vehicle. If I even suspect it’s not doing it’s job on even a 4.0 (since they are closely related to the 2.9), or if I’m swapping motors, pump gets warrantied. I’m not playing. Thermostat and water pump are cheap insurance. Also what is the condition of your clutch fan?
Water pump ive never touched.
I still had good heat, so id assume it was circulating, but that said ive never had a vehicle overheat when it was 5* out...so i dont know if that was a good indicator.
Im not sure. Something obviously went on. I drove it 3 mi to park it at the gas station after it cooled off and the temp gauge stayed right where it always did (O in norm). Even when i let it idle for a bit.
I always freak out and assume the worse. I pulled the dipstick but couldnt see much in the light from my phone. Hoses/belts all intact.
There was snot under the cap but not massive amounts. I dont know if it really got that hot...it did spew a little from the cap when i shut it off and opened hood but while running i dont think it got but maybe a needle tick above the normal band. On any other engine i wouldnt worry. But....it is a 2.9 as much as i hate to say that.
I know youre not supposed to shut off during an overheat but i was afraid it would keep creeping up...so i kinda had a choice to make.
Either way, ill know a bit more later today. Its suppoaed to be like 55 monday so ill probably see what really comes of it then.
