welding my frame
I had the same problem on my 99. The rear section (from the rear leaf spring shackle back) my frame was pretty much gone. I cut that section of frame out and went and bought a section from the JY. I didn't weld it personally, but one of my buddys did. Also, he vertically welded it on the inner and outer sides of the frame, then we used some steel plates side to side to give it more strength. My camera won't connect to my computer right now but i'll post some pics when I get it to work right. I'm sure it wasn't the "proper" thing to do, but it's pretty tough.
The best thing to do in that case would be to cut both pieces of frame on a 45 and weld them up on the diagonal.
I wish it would have been that easy. Small sections were literally rusted off. We had to make a clean cut straight down. From the info I have on the truck it was pretty much used near the coast or right on it because even my brake lines were rusted through. There was a nail in my master cylinder line running to the rear.
The BEST frame "splice" to weld in a patch section is a "double reverse fishmouth"
Essentially what this is is you section the frame in such a way that the piece being discarded has a "mouth" cut out of it as does the section of frame from the "donor" that you are not using so that the two pieces you ARE using each have a half fishplate "tab"
and they overlap when assembled like a "handshake"
then you "plate over" the flange top and bottom with a piece of steel that is atleast 24" long that is NEVER welded across the flange, but can be welded parallel to the edge of the flange and parallel to the radius.
Ford Acts like their frames are "rocket science" when infact they are plain
low-carbon mild steel hot rolled sheet stock that is hydroformed to shape.
The welds I did on my frame to install my 1"x2" rectangular spacer tubes
for my 1" body lift are welded to the combination cab/bed mount at the
front (full perimeter), parallel to the frame on each of the mid supports
(all eight of them. Yes, I have support blocks under ALL the cross bed box supports) and at the rear of the frame (three sides, parallel to the frame and across the back)
I really cannot believe that any welding I did weaken the frame,
infact I believe I've reinforced it because at each spot I welded
in a block I was essentially gusseting a spot wher the factory left
a 3/4" diameter HOLE in the flange.
AD
Strengthening a frame is not always a good thing. There are crush zones built into frames to allow them to crush and absorb the impact instead of your body absorbing the impact. You go plating over crush zones and you're not only putting yourself but others at risk. What happens if you reinforce your frame and instead of it crushing in an accident, it stays rigid and pierces things it's not supposed to (like people)?
Not trying to be harsh here, but there is alot more to the frame of your truck then you will ever know, and altering it in any way will result in changes in how it reacts in an accident.
:icon_cheers:
Have you ever modified suspension on any vehicle? The same can be said for factory suspension and people hack that off all the time.
:icon_cheers:
I'm working on gen1/gen2 frames which have no "crush initiation zones"
In the event of a rear end impact however the ranger frame is designed to bend down at two distinct points.
The frame bending down where THEY wanted it to would result
in compromising one or both fuel tanks I have back there, so I
couldn't really give a rat's ass what some engineer intended 20+years ago,
I am more concerned about what THIS engineer intends NOW.
especially since THIS engineer will be in the vehicle in the event
of any such collision...
You should see the metal we added to my brother's F250 supercab...
we reinforced the entire frame from just behind the cab to the
rear bumper mounts if the frame is going to fail it will fail UPWARDS by a tension failure of the top flange at the gap between the bed and the cab
because to fail any other way would require the failure (in tension)
of a 3"wide piece of 3/8" thick flatbar that is strapped along the bottom flange of the frame.
That truck will NEVER sag in the middle.
The rear springs are such that 3400# of coal compresses
the rear suspension by a whopping 2.5":)
AD
No. Never. :rolleyes:
Just because people do it, doesn't make it right. My intent was to inform the OP of the liability he is taking upon himself. Simple as that.
AD
See, with a post like yours, I'm not at fear for my life that I may pass your truck on the road someday. :icon_thumby:
But when the whole idea of a frame not being load bearing past the rear shock is introduced in a thread, I start to worry.
The funny part about all this, I just tore down an 01 Ranger today that totaled cause it needed a frame. It really wasn't a bad hit, knocked the right rail over about 40mm and the left rail over about 10mm. Technically, it could have been repaired. But because ford doesn't allow straightening of bends or kinks in convoluted sections, it had to be replaced, which brought it over the threshold.
Bottom line is, information never hurt anybody, but lack of information could. :icon_thumby:
Frankly what scares the crap out of me is relatively well constructed trucks
with reinforced frames and beefed suspensions running on tires NEVER designed or intended to carry the load...
AD
