weld it yourself coil buckets
Dugfab
I have a couple questions:
1.What is the static dimension from the upper & lower shock mount, which Fox shock model is used, and what coil spring did you use?
2.Is this used on a 4x4 or 2x4?
3.How much travel will this setup produce?
4. I assume you are using custom radius arms, do you fab those as well.
I'm very interested in this setup.
Thanks
