weird clunk noise
the kid
1996 ranger
i have a 1996 ranger with around 130,000 on the clock its a 4.0 stick. when you drive it every once in a while you hear a louad clunk. it souunds like a gear skipped a tooth. the clutch is new. dose any one have any idea on what it could be or where i should check first
Check the Universal joints? My 94 was doing that, most noticable when going from first to reverse or vice versa going slow such as in my driveway. But not all the time. Turns out the joint closest to the rear end had some slack in it. Replaced it and problem solved.
my ujoints do that but the joints are fine, its the mount bolts that back off a hair, i retorque every so often it goes away then comes back, even loctited the bolts same thing. ive learned to live w/ mine, maybe yours can be fixed.
