- Oct 15, 2020
- New York
- 2.9 V6
- Automatic
- Total Lift
- 2.5" Suspension
- Tire Size
- 31 x 10.5 x 15
1989 Ranger 2.9L 4x4 Automatic
So I just finished resealing the windshield, and I also replaced all of the trim clips with new ones. Everything went smoothly, although was a bit challenging since sometimes i had to remove some old seal/gasket material in order to properly install a new clip.
But in the end, the job went well and I was very thorough about sealing all edges and inner trim areas and also fully replacing the cut away seal where some clips went.
I took care to also allow those intentional dime sized holes under the windshield to remain open. There are a handful, maybe 4 or 5. I’m not 100% certain where they drain to but clearly they are meant to lead water down and away from the windshield. I would guess they go down into a channel that redirects them to either side of the truck and down to some drain spouts.
Over a day later, so well after the seal was dried, we had a rain storm in the middle of the night. The water in my floor boards was basically unchanged from before resealing the windshield. I have brand new carpeting in there, the under-padding of which does a good job and soaking it up and slowly drying over time. But i have to correct this for sure.
I’m really not sure where the water gets in at this point. I had assumed it was the windshield trim, or at least SOME of it was from the windshield trim. But it apparently made no difference after it was fully sealed.
I’m starting to wonder if maybe i will have to open up the whole dash to figure this out. Maybe there is something relating to the air vent/heat/AC compartments that is allowing water to drip in?
It’s far worse on the passenger side. It’s also dangerously close to the computer brain. It certainly wouldn’t be good to have water zap that thing while driving in a storm !
Anybody have any similar experience to shed some light?
