Heres the basic question in its simplest form:
how tall of a spacer should i use. I have enough washers for a 2" stack.
Heres the info that is required to answer that question:
My truck has zero camber as it is, and the axle pivot bolts are maxed out in the up direction (see picture). I want to set those cam bolts to their lowest position on the bracket, and then use washers to get back to someplace that is still alignable and achieving ride height lift. The cam bolts, if moved from the top most position to the lowest is exactly one inch (from center of bolt head to center of bolt head)....that means there is one inch of adjustment on the bracket; how many degrees that is, is way beyond me.
I have 1-1/2" of usable thread on the stud for the coil nut.
I know the ttb has a 1.5:1 lift ratio, but i only kno that from the current setting on the cam bolts and not with them in the extreme opposite setting.
I need someone with an engineering background or is generally just smart to maybe help me work through this problem to figure out about how many washers i should use so that 1 i can still align it and 2 get the most lift out of it. I would rather not take everything apart twice or more times to dial it in. but if i must i must....but maybe an internet discussion can eliminate this .
From what I have thought about it needs all of 1.5" of washers to make up for the massive amount of negative camber it will have when I move the cams to the lowest position and still lift the truck to a higher ride height.
Cam bolt is at bottom of both passenger and drivers side TTB brackets (tuff country made). Both are set to their highest position within their adjustment range.
Whew lots of typing. If i need to explain more or clarify please let me kno! Thanks!!!
