Want to crank but a question first
JaBradt85
Albany, NY
I want to crank on my t-bars make the truck sit level. My question is will this mess anything up in my fornt end you know with axle angles, ball joints, tie rod angles?
http://www.therangerstation.com/tech_library/TorsionBar.html
7) (IMPORTANT).. get a lifetime alignment (usually $100). this way, you can modify them and get it re-aligned for free. If you do not get the alignment, It will ROAST a set of tires REAL Quick.
you should check out the tech library before posting, it answers alot of the common questions
My bust I did a quick search but couldnt come up with what I was looking for I forgot about the tech library. I apologize for wasting peoples time.
No problem...wasnt yelling at ya, just letting you know its there ;)
